12 S plug and socket
Why has the centre pin of this plug been getting hot. Its cracked the surrounding plastic. Bazz.
Jul 15, 2005
2,175
Hi Bazz,
You need to replace the S plug and socket, once they heat up they're best replaced.
But why? The 12N and S connector are a simple push fit, and need careful use and maintenance to achieve long lasting, good electrical connections. The deficiencies in the design include:
1. The brass pins have a slot cut in them so they can be prised apart and restore a tight electrical connection - loose fitting means high resistance and the connection heats up.
2. They are made of brass, which will corrode in UK weather - and that means high resistance and the connection heats up.
3. The pin allocation was changed about 10 years ago - and in what has turned out to be a mistake, the fridge return was changed to the centre pin - which is also the guide pin to align the plug and socket - easy knocked, this afters the connection, and the connection heats up.
The fridge draws 10+ amps and this all needs to return via that central pin, and pin burn out is a common problem.
The only permanent solution is to change the twin 12N+S for the superior 13 pin ISO connector...
Robert
