937
Ann, what van do you have?
Have you switched the selector switch to Van?
With 12v the only things which will work are the 12v lights, water pump, toilet flush and heater fan
Oct 19, 2006
21
STERLING EXPLORER 2006 FRIDGE NEON WILL WORK BUT NOTHING ELSE IE PUMP HEATER FAN STEREO LIGHTS ANYTHING 12VOLT HUBBY HAS METER ON POWER SUPPLY FROM BATTERY BOX AND IT IS THERE BATTERY LOOKS OK HAVE LEFT PLUGGED INTO MAINS OVERNIGHT TO SEE IF BATTERY IS FLAT ALTHOUGH IT IS SHOWING GREEN
Ann, Can you please confirm that it is the fridge 12v neon that is is on and you are nit talking about the mains one? Ray
Oct 19, 2006
21
Hi Ray its a thetford fridge and its the little blue one that flashes and then goes solid when connected to car Ann
46
19,185
I had the same problem with our van and it was simply the fuse had dislodged, simple but it took me long enough to twig it!!
Oct 19, 2006
21
Hi All
Many thanks have been reading past forum probs and noticed it mention a key fob for turning the inside light on as you walk up to van had a play and it is now working (why you need this gimmick is beyond me and of course no mention in handbook) but all domestics have ceased cos of course it was each other that had caused it We can now go away again for first outing this year the start of many good weekends Thanks Ann
