12v inverter
Oct 24, 2006
44
I'm looking to buy a 12v inverter to power the laptop on our trip to south france.Can anyone aadvise as to which one to buy, also do i need to look at 150 watt or higher.
Thanks.
4,132
1,866
490
Does this mean that you are going to the South of France and not using mains electricity at all on your trip?
Mar 24, 2009
353
Not sure why you need to go down that road, I simply plug my laptop in to the car or caravan.
Although my mains adaptor is 240v ac to 20v dc, it works perfectly on 12 v dc
938
The description of the inverter referred to above doesn't say whether it produces true sine wave AC current or not. Judging by the price it probably doesn't. Although this may not be an issue for powering a laptop, because the laptop's power pack converts back into DC anyway, some electrical equipment will not work unless current is true sine wave.
I bought a 1200 watt pure sine wave inverter for around
4,132
1,866
I am pretty confident, given the price to assume that the cheap Ring 75 is only a modified sine-wave inverter. However I run various and many other product AC adaptors from this unit and its bigger 150 Watt sister, all without issues.
Mar 10, 2006
3,274
47
I would go for the 150w version myself, the extra capacity can be used for other applications. I use my 150w inverter to run a LCD tv, HUMAX, and ariel amplifier, should there be a power cut, i then plug the inverter into the 12volt caravan socket (some new vans don't have one, so you may need to wire one).
Needless to say the tv and humax are full of electronics.
Nov 28, 2007
490
12
18,685
Unless you go for an expensive sine wave output inverter, the cheaper ones may not do your electronics much good. I needed a laptop power supply to connect to the 12V car / caravan system recently for my new Dell lap top, I first tried using my cheapish inverter with the standard 240 to 19.5V power supply but noted that the dell power supply hummed somewhat with it, which may not be that good. (I cheated and used my works dell to test it). In the end I bought a 12V to 19.5V (Dells odd voltage) converter and that works well. I got it from ebay.
Oct 24, 2006
44
What I'm after is something to run the laptop for the lads to watch dvd's whilst driving, we'll have hookup when on site.
Jul 11, 2006
490
The answer to that is simple - buy a twin screen DVD player. The screens are usually about 7", they hook over the front headrests, and there is at least two headphone outlets on the player. The player either runs from 12V or comes with a 12V convertor.
They used to be expensive, but you can now get them for
Oct 24, 2006
44
Oct 24, 2006
44
Oct 24, 2006
44
I was going to buy the dvd players that go over the head
rests but the inverters seem to be a much cheaper option-that's the reason for advice on them.
Michael t, I've just bought an inverter from Maplins, a 300w one, and use it to charge herself's mobility scooter when in the car. Works a treat.
