13 pin socket
Apr 28, 2009
13
pin1 lh indicator
pin2 fog
pin3 common return for 1-2 &4-8
pin4 rh indicator
pin5 rh tail lights
pin6 brake light
pin7 lh tail lights
pin 8 reverser
pin9 permanent power supply
pin 10 power supply controlled by ignition
pin 11 return for contact 10
pin 12 reserved for future allocation
pin 13 return for contact 9
Jun 11, 2012
1,525
28
19,685
K here we go . this is what you need I think contat number1L/H indicator.
2 Rear fogs.
3 Earth retur
4 R/H indicatorn
5 R/Htail and No plates
6 Stop lamps
7 L/Hand no plate
8 Reversing lights
9 power supply steady
10 power supply ignition
11 earth return connect to 10
12 no allocation
13 earth return contact no 9
All using 0.65mm wiring
I hope this helps you
Sir Roger
936
http://www.sargentltd.co.uk/ISO11446_Data.pdf
That gives the FACE view of the plug.
If you are using the existing two 7 core cables, the black 12n is used on pins 1 to 7
Pin 8 uses Yellow from 12s
Pin 9 uses Green
Pin10 uses Red
Pin 11 uses Black
Pin 12 uses Brown
Pin 13 uses White
The Blue from the 12s cable is not used.
May 7, 2009
69
Pin 9 uses Green
Pin10 uses Red
Pin 11 uses Black
Pin 12 uses Brown
Pin 13 uses White
Big thank you to all on that one regards k.
