Hello John,
Ray has correctly identified that the force/pull you require will be significantly less than the actual weight of the caravan, unless you are trying to lift it vertically!
Consider a caravan that weights 1000Kg (1 Tonne). To lift it you would reaquire a pull of 1Tonne. If the caravan is on a 45 degree slope, to pull it up the plane of the slope you would need 500Kg pull, and teh lower teh slope teh less pull you would need. You obviously have to overcome the rolling resitance which adds a little bit perhaps 50Kg. As a rule of thumb if you divide teh weight of teh caravan by the angle of teh slope, and then add 20% (to overcome rolling resistance and compensate for teh approximation of a rt angle only having 90 degrees compared to 100 degree) you will estimate the minimum pulling power you will need to move the caravan.
So assuming 1200Kg caravan (MPTLM) 10Degree angle slope gives 120Kg + 24Kg (20%) = 144Kg Est. so your 900KG will cope very well.
