colin-yorkshire said:
hi Prof, without seeming to be too flippant why is the answer to every unusual difficult question get the pro's in and pay :woohoo: there are lots of professionals on hand but not one has a clue what it is so why would the local van man be any different..
Hello Colin,
I'm not trying to curtail the spirit of adventure, but in this case, the problem seems to be outside of our experience, thus any advice about what the cable and plug could be for is pure speculation on our part. As I have said on other threads we simply do not have the necessary information to be able to offer any informed advice.
Dave hasn't been able to identify its purpose even with the helpful comments already made, so it suggest the OP is not conversant with electrics, and thus is probably unable to confirm the safety or otherwise of the systems in the caravan. For this reason alone it would be wise to use a professional.
But the other advantage of using a local pro, is they can physically look and prod to find out what its all about, in ways that are virtually impossible for us to do over the WWW.
If the cable is the result of someones miss informed tinkering, then it begs the question what other none standard work has been carried out in the caravan.
We are quite likely dealing with an electrical system, and if it is none standard, then the risks of the system need to be properly assessed and if necessary made safe.
Your observations are interesting, and whilst the visually descriptions are fair, its pure assumption as to function and the circuits to which its connected.
As you know there are certain aspects of caravanning that are subject to regulation, and for reasons of compliance with the law, it is necessary to employ a professional. There are also some aspects of caravanning that may not be directly regulated, but because of the nature of function or material, it is not advisable for DIYers to attempt to carry out work as they will not have the necessary full knowledge or equipment to ensure the safety of the work they do, so again the sensible thing is to use a professional.
We must not loose sight of the fact that not all caravanners have the same universal skills, so when offering advice it may at times seem over bearing to those who do possess the knowledge or skills. We have to consider the lowest common denominator, and uphold best practice for safety.
