Hi Mr G. Thanks for both as you can see using the photo attachment below.
Right lets have a go at some of this
First off as you brought off ebay I would advise you get the van serviced the engineer will use a check list to go through every thing
from tyres to damp to electrics and gas leaks, (You could also use him to your advantage ask him loads of questions)
Dont know what area you are in but there ate mobile engineers all over the country, prices vary but as a guide we paid £180.00
plus parts last year.
Yeah have all those, have tested Gas, heater works and air blowers, cooker also works. Not sure if Gas does the Fridge though???
Look in the fridge and see if there is a glass "spy hole" this is where you will see the pilot light when lit. Dont know how to ignite yours at this stage,sorry
I have am aquaroll, and have a chrystal maxi pump, but not sure if it for the aquaroll for the waiste... stupid i know
The pump goes inside your aquarol when full of water and on the outside of teh van you will have a flap that lifts up and the pump will connect there.when the pump switch is turned on and you turn a tap on the water should flow, thats the basic's for now (you may encounter air locks and gurgling but come back to us if that occurs)
Not sure on most of the following
This is what is under the fron seat, when i press thesilver boc on right from 0 - 1 the mains comes on but not sure how the leisure battery kicks in.. dont know what the other boxes ar for or how to use.
Not sure if this looks right, guessing fuses
The heating works but dont understand the settings on the black controller it works on the arrow but not '0' or 'A', Not what the Carver switch is when on greet heater works from Gas...
couls you also tell me what the fuse switch is...
This could be the main switch for the water heater, but only a guess from me at this stage, make sure you have pumped water into the stystem before switching this one on
This is above the cooker and when mains on not sure what the Car/van button is,
When in the van switch to van, when hooked up to car switch to car and the fridge should work as you travel to sites
This again is above the cooker and not sure about the pump button
This could be the pump button I refered to earlier, switch it on for water
In essence, and you may have gathered, i have little idea about what does what in the caravan.... the switching from the mains to battery and gas is all confusing.. have tried my leisure battery but not sure if there is life in it.. i guess not.
The van should have two lots of lighting and at this stage to check the battery disconnect the mains cable and try some of the lights
normally at least two should be on the battery. Then switch them off, connect mains cable and try the rest of the lights.
Hope some of this is of some help, good luck and come back to us with any other questions
Many many thanks for bearing with me.
Peter
