Ace Award Nightstar 2005
Jun 20, 2010
Hi, my friend has just bought a new caravan but is struggling with the rear L-shaped dinette cushions. I have had a good as we have just recently sold a Swift Alouette with the same layout and I haven't got a clue how the cushions should be when making it into a bed. It does appear to have shaped bits for interlocking, but they make no sense at all. Can anyone help please.
Helen
Mar 19, 2010
26
We have a 2006 model and it is quite straight forward if it is the same.
Pull the slats out from under the rear window towards the door, over the lug so the are firmly in place.
Slide the seat cushion from under the rear window towards you as far as it will go - right up to the edge by the door.
lay the backrest from under the rear window down and pull up against the seat cushion.
Now take the backrest from under the side window, and it should fit in the gap.
You are left with the funny shaped bit from the corner - this is unneeded and just needs to be put somewhere out of the way
If that doesn't make sense if you let me have an email address I will send a diagram!
Owen
