anyone know how to get rid of slight condensation from within the double glazing of acrylic windows? It is only early in the day it appears and seems to go whenever the sun gets to the window.
Hi Mick.Never had that problem personally but i did see a previous answer which suggested removing the little rubber/plastic bung at bottom of window and running a hairdryer on low heat inside until the condensation goes.
this is a common problem,when the sun comes on the window it warms up and the problem disappears, the moisture is still there
but the warmth vapourises the liquid, warm the inside of the windows, but the bungs are usually at the top and difficult to get out they can drop inside if you are not careful
