Do you need to vent an AGM battery? If not, then there should be no issue moving it from the front locker to under the island bed immediately to the rear of the axle.
I'm not sure if my Elecsol110 Carbon battery was AGM but it was sealed and lasted 10 years. This summer while away on electric hook up it overheated (too hot to touch) and swelled in size. As the Prof says "Under Normal Conditions" . . But you never know when normal conditions change.Do you need to vent an AGM battery? If not, then there should be no issue moving it from the front locker to under the island bed immediately to the rear of the axle.
Elecsol were not AGM, but you got a good life from it at 10 years.I'm not sure if my Elecsol110 Carbon battery was AGM but it was sealed and lasted 10 years. This summer while away on electric hook up it overheated (too hot to touch) and swelled in size. As the Prof says "Under Normal Conditions" . . But you never know when normal conditions change.
