air awning leak
May 15, 2014
26
hi I have an air awning sorry I do not know the make of it.i have gone to inflate ther awning and have an air leak around the intake valves is there anyway to fix these really gutted had it about 10 months third time I have used it any help appreciated. :(
4,987
Oh dear! If you don't know the make how can we help you.The manufacturers use different inflation systems. How do you know the leak is where you say?
Give us more info and we will try and help.
May 15, 2014
26
I have inflated it and can hear the air coming ou.i have tried tightening it but it but still the same was wondering if there is a fixing kit I can use.
4,987
Okay we still don't know the make :eek:hmy:
Remove the inner tube. You will have to disconnect the pipe work first. Make sure you note carefully how each joint is assembled including the o rings. They are tapered. Once removed see up the ports and gently partially inflate and locate the leak . A bucket of water will help.
Repair kits are available but maker specific. Quite frankly a new tube is your best bet.
Hope this helps. It really will help if you can tell us the make.
