What are peoples thoughts on air awnings?
Have they improved, in design, over the last couple of years?
Too heavy for one person, do you think?We like air awnings, but they can be heavy. For us, still easier than the poled variety.
mel
No, if you think about which one to have. The ones with the single front beam (and a not attached separate middle joist) are well within the capabilities of one person. We have one of these, as does Hutch. We also have a large 4 beam Vango. That would be much harder work for one person as the weight tends to drag it down out of the rail opening as you are trying to feed it through. It is also ridiculously heavy to carry.Too heavy for one person, do you think?
I’ve got a kampa awning 3 mtr so near enough covers the side of the caravan, I struggled to start and then on the advice of I think Mel I bought the kampa pulley kit which wasn’t expensive and now I can erect the awning on my own, I erect it without the windows zipped in, I put them in once the main part is erected and then put the windows one at a time, not too hard at all.
Best awning I’ve had and the kampa is the best to date of many I’ve tried over the years
Well took your advice, went off to have a look at some air awnings.
Came away with a Star Camp 225 (made by Dorma) Almost identical to Hutches, and one of thoughs Dometic Awning Pully, What-nots, thanks Chatter. Sucker for a good sales pitch--------- me.
I hope you be very happy with it enjoyWell took your advice, went off to have a look at some air awnings.
I carry a roll of clear Gorrila tape, really good for the airAwning tubes.Air awnings are great and we have a Dorema magnum. Easy to erect BUT if an air beam pops then the only repair is to replace the beam with new. Bit of a hassle if you’re half way through your holiday in the wilds of France. Recommend you buy spares and as stated don’t inflate to full pressure in hot weather.
The beams weak spot is the end crimp.
Cheers
Yeah, tried that, tried mastic sealer tape, super glue even a warmed up steel bar to try and reweld the seam. All failed. A straight forward puncture isn’t the problem. As you say tape usually works but once the end weld has popped then it’s game over.I carry a roll of clear Gorrila tape, really good for the airAwning tubes.
If it's the end weld, then try using , a food vacuum sealer, to weld another couple of seals, no need to vacuum it of course.Yeah, tried that, tried mastic sealer tape, super glue even a warmed up steel bar to try and reweld the seam. All failed. A straight forward puncture isn’t the problem. As you say tape usually works but once the end weld has popped then it’s game over.
Yes good tip that maybe the way to go. Good thinking Curruthers. Still not something I would want to pack in my holiday bag 🤔If it's the end weld, then try using , a food vacuum sealer, to weld another couple of seals, no need to vacuum it of course.
Just another bit of caravanning kit to carry to use up our excesse payload. 😅Yes good tip that maybe the way to go. Good thinking Curruthers. Still not something I would want to pack in my holiday bag 🤔
