Hello Tim,
I haven't used one of these, but I have looked closely at AC in caravans for a manufacture in the past.
One of the persistent problems with most AC units in caravans, including your mobile unit is the fact that both the evaporator and the condenser coils share the same box, and thus the exterior air has to be ducted in and out. This always compromises performance and leads to an increase in the noise the unit produces inside the caravan.
The the "cool my camper" gets round those two issues by mounting each coil with its own fan in two separate boxes. This is good for the occupants, but it may cause an increased annoyance to other site users as there is one fan completely external to the caravan. How much annoyance I cannot say as the web site does not mention noise figures.
As to how effective it will be :-
In essence AC cools the volume of air inside the space. So in simple terms the power consumption of the AC unit should be divided by volume of air it is expected to cool.
This gives a figure of Watts per cubic Metre (W/m3) this will enable rough comparisons to be made with other systems you may be familiar with.
Many modern cars also have air conditioning. This is a compressor driven system with mechanical power being taken from the engine. There is also some electrical power needed to operate the cabin blower, and the external condenser coil fan. The power needed for these systems varies depending on the model of the car, and can range from 5 to 10 horse power, Typically close to about 7Hp or about 5kW (1hp = 746W =0.746kW)
a typical saloon car has an occupancy space of about 4 cubic metres, so the watts per cubic meter is about 5000/4 = 1250W/m3
The "cool my camper" also uses a compressor driven system with two fans for moving air, but in this case the whole appliance is electrically driven. It specification claims a consumption of 350W.
The volume of a 3.6m (12ft) caravan will be typically 13 cubic metres, so the watts per cubic meter is about 350/13 = 26.9W/m3 (obviously larger caravans will see even lower W/m3 results)
So comparing a small caravan to a typical saloon car you can see based on power consumption figure the "cool my camper" is 26.9/1250 = 0.02 or only 2% as powerful!
Now a minor miracal seems to have been performed beacuse they claim that the 350W actually becomes 700W of cooling! even allowing for their miraculous gain that only makes it 4%, still a long way off the cars system.
It is difficult to be absolutely fair as there are lots of unknowns and vairaibles, but the margin of difference is so large that it is fair to say that the performance of the "cool my camper" unit in cooling a caravan will be vastly inferior to that of an AC system in a car.
However, it is clearly unreasonable to expect the "cool my camper" to cool an entire caravan, but most people are actually find that having air movement over their face or exposed skin is quite refreshing. Consequently if the unit is used so it directs its cooled air onto your face you will certainly find it better than nothing, But you might find you get the same effect by simply using an oscillating fan to move the air around in the caravan.
If you decide to go ahead and buy a "cool my camper" unit make it absolutely clear to the seller what purpose your expect it to perform, what volume of caravan it is expected to work in and how much you expect it cool it down – actually write it down in detail and send it to them before you purchase. This make your requirement an expressed term of your order and contract with the seller. If the seller feels the unit cannot meet your requirements they will not supply it.
On the other hand if they do supply it, it means they guarantee it will do what you want. However if it doesn’t meet your expressed requirements, then they are in breech of contact for supply a product that is not fit for purpose, and they are legally obliged to either supply a unit that does perform to your specification or make a full refund including P&P.
