Hi . Filled aquaroll as usual, connected up pump . Removed all air from system and hot water all fine through taps etc. Then within a day the taps are gurgling , no hot water and have to repeat process. Can anyone advise. Many Thanks
WoodlandsCamper said:Sounds like one of the non-return valves isn't working correct and leaking water back to the aquaroll, or more seriously you have a leak in the pipework. Trace all your pipework to see if there is a leak somewhere.
