- Aug 24, 2007
- 7
- 0
- 0
when you turn your hot tap on for the first time it spits air for a few minutes which i no is normal, but after a few hours when you want to use the hot tap again you have to go through this process again,as if the water is running back and i noticed when i disconnect the outside water pipe a small spray of water sprays out.can any one help with some advice
