Trying to explain the finer points, when you buy an appliance, say a kettle, the load taken is dependant on the resistance of the element. So a 2Kw kettle would have a current rating (not called amperage by the pedantic) of about 2000w/230v - 8.7A Resistance is Volts/ amps, ie 230/ 8.7 - 26ohms. The current taken will be the supply voltage at the socket outlet / 26A. As said, volt drop from 230 volts will depend on the cable length, conductor size, ambient temperature and the actual current carried at that time. There is almost always an allowance for the fact that not all appliances, (or pitches) are in use at one time, the term used is Diversity. As the voltage drops the resistance is constant, the current falls, and less current means less heat, which is the point made earlier. Power factor,also mentioned earlier, is only present in inductive circuits (sorry for confusion, kettles no, Compressor fridges yes otherwise no etc so irrelevant to us) and results in a higher current than calculated by these equations, especially if harmonice are involved. So, why not just keep it simple, use power as responsibly as possible and enjoy your caranning.
