Have you seen this new awning just peg the back down & blow it up!!!!, bit pricey compared with traditional pole type though
Kampa Rally Air 390 - The quickest awning you'll ever buy.
The revolutionary Kampa Rally 390 AirFrame awning designed exclusively for Kampa can be unpacked and erected in under 5 mins.
No poles, all you need is a pump, a pitch and a caravan. Made from 'Feel the difference' heavy duty 150D Weathershield materials the Rally Air boasts the same build quality that has fast made Kampa a class leader in lightweight caravan porch awnings.
The new Rally Air uses a revolutionary 'AirFrame' system, which as the name suggests is an inflatable integrated pole system which provides the awning with both structure and support. The AirFrame is inconspicuous, thoughtfully designed and robust, really robust, once inflated the awning is incredibly strong, deceptively so.At first glance the Kampa Rally Air looks like a traditional Rally porch awning, elegant and eye catching. But there's something you can't quite put your finger on. Sure the awning is a Kampa Rally shape and has the characteristic profile of the now well respected Kampa Rally Range; good headroom height, bright clear windows with the new Rally Club window shape that have radius corners. But where are the external poles?
The rigidity of the product is something you have to see to believe. Lateral movement is minimal when either wind or force is applied - much more so than a pole system. This has been made possible by the modular internal AirFrame. Above each window section is an AirBeam support sandwiched between the vertical uprights. Pressure laterally is absorbed and spread across the awning forcing the air pressure to increase in the horizontal beam. Clever indeed. You would expect the AirFrame to be big and cumbersome to live with, but the internal space isn't compromised by the frame at all.
