- Apr 6, 2008
- 71
- 0
- 0
Not sure what is causing this problem, hope someone out there can help.
When on site, we connect up the water pump and place in the barrel, go in the van, switch on the pump, turn on the tap, no water. There is electric to the pump, so leave the tap on and maybe after an hour, less, or more the pump suddenly starts working and we have water, things can be ok for a day or two, then turn on the tap and once again no water, so leave the tap on and the same thing happens again.
Can anyone help as to what is causing this problem.
Checked the filter is tight, the pump is yet another new one, we now have three and there is a 12 volt supply at the socket.
Thank you
Thank you
