Another Question for Lutz - Sorry
Aug 28, 2005
603
Lutz,
We've got a Dethleff's New Line (2000) German Spec - Do you think the reading/spot lights are working off 220/230V or are they 12 V via a transformer, I suspect the latter. But it's guess work, the RCD is pretty much a sealed unit. Out of interest the main lights takes a normal bulb
Any help would be appreciated
Monkeys husband
3,845
Hello Monkey's husband
Disconnect the caravan from the mains supply and try the lights if they work they must be 12V from the battery.
Alternatively It should be easy to check by removing one of the bulbs and reading the impressed information on the bayonet/edison screw. That will tell what the voltage and wattage is.
832
I don't know an awful lot about Dethleffs (I've got a Knaus with battery) but I strongly suspect that the reading lights are 12v running off a transformer. As Rod says, most German caravans are like that.
Oct 1, 2005
84
Ive only been in 1 dethleffs and it didnt have a battery, it only ran the 12v from transformer, dont know what the lights were.
Aug 28, 2005
603
Thanks Gents,
For your help, Sorry forgot to say we don't have a battery fitted, though to be honest we would never use 12 V as we usually go CC sites with facilities and they always provide hook ups.
Regards
832
Although German caravans often don't have a battery, lighting is still usually 12v and runs off a transformer.
