I have an Elddis Xplore with a crack in the ABS front panel that I need to repair. I can get to the inside of the panel via the space between the front lockers, so I am looking to brace across the back of the crack rather than using heated staples from the outside, and hopefully minimising cosmetic work on the outside. Does anyone recommend a good product to give as much strength to the repair as well as preventing ingress (I have drilled a hole at the end of the crack to prevent it spreading) by bonding the panel, whilst remaining flexible enough to move with the panel when under tow, given it is on the nearside of the Van and therefore possibly more prone to movement? I am thinking of something like Innotec Repoplast?
