Hi everyone. I could do with Some advice about what is the best TV Ariel in a poor signal as area. I don't want to attach it to my van as it is vintage so would be mounted on a pole. I would appreciate any advice as there are soooo many .π
Yes agree...I have looked into it and I just don't want to spend alot and not get the results. It's always good to hear from someone who has had this issue on a site and done the legwork and solved it π thanks for the response anywayI have not used a stand alone aerial for some years and then only the one model so never had the chance to compare. Possibly the best advice I can give is look at the price and spec. You tend to get what you pay for so the cheap ones will be just that.
Caravan TV reception suffers from lack of height, compared to domestic aerials. In areas with poor terrestrial TV signal, you're better using a satellite receiver and dish.Hi everyone. I could do with Some advice about what is the best TV Ariel in a poor signal as area. I don't want to attach it to my van as it is vintage so would be mounted on a pole. I would appreciate any advice as there are soooo many .π
This might be suitable Image 630 Digital Antenna SystemHi everyone. I could do with Some advice about what is the best TV Ariel in a poor signal as area. I don't want to attach it to my van as it is vintage so would be mounted on a pole. I would appreciate any advice as there are soooo many .π
Log periodic aerials are normally only used in good signal areas - for poor signal areas, a High Gain X-type is needed but they're cumbersome to store in a caravan!I donβt fully agree with Roger. Height could be a factor but since the age of digital terrestrial TV, signal coverage and strength have vastly improved.
I would suggest that you make up your own from domestic TV parts. (Much cheaper than those supplied for caravans). A logarithmic type are smaller and easier to store. If the jockey wheel is easy to remove you can get poles to fit in there.
Hi Kimykou,Thanks all...I have considered a satalite receiver...will this pick up signal better than digital...do they need power too.? As for making up my own I really don't have the skills π
can't see any reason why it wouldn't work in a caravan
The television we use in the caravan has a satellite decoder (set top box not required),the only problem we have is the decoder sees everything coming from the satellite and does not arrange channels in numerical order.still playing about with it.If your TV has a built in satellite decoder then you are way along the road to using that system.
All it then requires is a quality coax cable to a dish, where the dish has its own built on LNB, an electronic bit and some mounting usually here a tripod.
Whilst the dish's LNB requires power this is generated in the TV's decoder and sent down the cable probably without many users ever knowing about that feature.
Here in the UK if the dish can "see" the satellite you can get a first rate signal; there can be issues with trees blocking its view, otherwise everywhere here it will work. They don't need to be up on poles as coming down an extra few feet after travelling thousands of miles is totally irrelevant.
For UK channels only a small dish is needed here, and is easier to set up.
Larger dishes are required to enjoy home TV on the continent, and even doing that can become impossible if too far away from the UK.
Setting it up to "see" the satellite seems challenging for some, but I struggle to understand why. Where I have helped they have failed to be systematic in their basic approach.
Thanks for all your posts
I feel a bit confused by it all..i am a bit of a see it n build it girl so maybe I should see what people are using on the site I am going to be on for the next season. πI was really looking for a recommendation. X
Thanks... shall take advise πOkay then, you said initially it was a poor signal area, but are others using aerials?
If so then despite the "poor" signal it is at least viable, so should be no different for you.
The easiest, with the best gain readily purchased is an Image 440 LINK, probably with one of its mast pole options mentioned on that website.
Used together with a signal booster if needed, my choice being a Fringe one LINK.
The Easy Boost, the more expensive features a useful but not vital array of LEDs that help find the best direction to point the aerial, the much cheaper Easy Boost does not have that feature but otherwise works as well, the TV will quickly let you know about aerial direction.
When on site, or better still on houses near, check it there are more aerials used "horizontal" or "vertical", and follow the trend with yours.
There are undoubtedly very much cheaper options but this is decent kit well made for our usage, at a price.
All the mobile phone operators tell me I live in a strong signal area, I can just about send and receive text messages on most networks, but only one provider is stable enough for voice calls and we can only use them when we are close to a window on one side of the house.
Its all about location.
As I mentioned I want to get the best option first time not buy and buy again
