I decided to have look to see if the heater pipe, under the floor, to the wash room was insulated. I think it is, but none of the measurements tally.
The OD of the heater pipe in the van is 65 mm as against the 72 mm spec. The OD of what looks like the pipe insulation under the van is 75 mm as against 85 mm spec. If these sizes are nominal they must be nominal plus.
Is this normal on 2012 Swifts. ???
