Avondale Dart 475 wheel size help
May 16, 2012
We bought a Milenco wheel clamp with the above caravan. No longer have van but want to sell the wheel clamp. Problem is we don't know what size wheels it fits . Can anyone help please?
3,601
I assume you no longer have the box or the instructions for the clamp, as these would have told you what size wheels it will fit.
But failing that, and as the informtion is quite specific, I suggest you contact the manufacturer direct (after all you do have email facilities), then at lest you can have a high certanty the infomation will be correct.
Oct 30, 2009
1,542
good idea, or you could just assemble the clamp dry, lie it down on it's back and measure the distance from the center to the inside of the top clamp, then double it!! this measurement will be the max size of wheel "with tyre" that the clamp will fit.
