Hi John,
This is a common problem. If you cannot obtain a handbook the following formula may be useful.
A = Maximum loaded weight of caravan (there should be a plate on the 'van stating this figure).(Say 1300kg)
B = Maximum tyre pressure (stamped on tyre catcass) (Say 73psi)
C= Maximum load of tyre (stamped on tyre carcass)(Say 900kgs)
D = Number of wheels. (Say 2)
Multiply A - by B divided by C - then divide the result by D = this is the approximate tyre pressure.
i.e. :- 1311 x 73/900 = 106.3 divide this by number of wheels (2) = 53.2psi.
The figures above are based on my caravan, the handbook of which states tyre pressures are 54psi.
It sounds a bit complicated but is reasonably accurate if you have no other option.
Ron
