Hi,
We Purchased an Elddis superstorm last year which came with an AWD motor mover.
We could never get the motor mover to work. This last time we were away we realised the previous owner had put an unsuitable battery in the caravan which we have now replaced. We've had variations of the following:
Front both engage and rotate
All engage but one rear side one wont rotate
The New Battery is fully charged 12.8 volts.
We were then in a situation where the 3 engage and 1 does not, the 1 that doesn't can rotate but the other back one engages but doesn't rotate.
We replaced the bushes on the two problematic ones - when we change the one that engaged but didn't rotate, nothing changed.
When we replaced the one that rotated but wouldn't engage all of a sudden nothing worked.
We put the old bushes back on this one and now are in a situation where the light on the box goes green once you turn the isolator switch on but as soon as you try to press any buttons on the remote, it starts to move then cuts out, box lights go off and its all dead!
Any hints of tips on where to start with our trouble shooting.
Extra info is we had to replace the whole unit that holds the battery as the hinge broke - I have also changed the fuse between the isolation switch and the box
