Awning
Apr 5, 2019
24
4,515
Does anybody know if there are any caravan porch awnings where the awning stays in the caravan rail at the rear of caravan to help stop drafts
3,414
32,935
We have the Isabella Magnum porch awning which has cushions that go flush against the side of the caravan preventing draughts.
2,065
We have a Vango Capella 220 Air porch awning this has a Draught seal system it creates a tight seal between awning and caravan ensuring no draughts come into your awning
Apr 5, 2019
24
4,515
Thanks for answering I have a Dash 390 air with cushions but just wondered if there was anything else out there that just stayed anchored to caravan at rear so only had cushion near the door
332
19,435
If you sre looking to get a snug fit porch awning, you can use a small full size awning,measure from the ground at the rear of the van around the awning rail until just in front of the door, then add the measurement from the awning rail vertical to the floor, the total will be the size of awning you need.You then need to buy an adaptor pole from Isabella that comes with pads.You thread the awning into the channel until it touches the floor at the back,You then cut into the awning bead at the point where you want the front vertical drop to be, you then feed the awning bead down the adaptor pole and the pads press against the side of the van.The awning bead will be in the channel all the way round and down the back of the van so no draughts.Will only work with a poled awning,but will certainly give you what you are asking for, maybe worth looking on e bay for adaptor pole, that was where we sold ours when we changed to air.You may also find a suitable poled awning as small ones seem less popular.
Reactions: Mel
1,312
Weren’t such awnings called Combi awnings. Isabella used to make them. Not sure that they do anymore??
mel
Reactions: JTQ
Apr 5, 2019
24
4,515
Hi thanks great idea
3,558
I too have an Izzy Magnum. The padded section is further pushed into the caravan wall by two vertical poles making it pretty well draft proof
