Axle stands
May 14, 2012
Hello
I'm considering leaving my caravan on a seasonal pitch this year.
Could anyone advise whether I should use axle stands or not as I've been told by a neighbour that this would be a good idea. Have never noticed any on site like this before though!
Regards
LB
Apr 13, 2009
225
6
18,585
Mmmm! not sure myself that this would be a good idea. Even if the 'van was parked on a really hard surface, there wouldn't be a lot of ground contact? You might want to consider concrete blocks under the axle perhaps. You can obtain those heavy plates that go on instead of the wheels I believe? then you would benefit by black bagging the flat tyres on wheels to prevent decomposing of the rubber. Hope this helps.
Apr 7, 2008
4,909
I use a pair of these primary axle stands, over winter & when the van is not going to be used for some time, they are easy to use & you will be able to level the van side to side a lot easy-er than using concrete blocks.......
I jack my van up & then adjust them till the tyres are just clear of the ground, you do not get fine adjustment with concrete blocks but there again they are cheeper
Aug 25, 2010
167
Something in the back of my muddled head tells me that Alko recommend 'relaxing' suspension rubbers in the axle by taking 60% of the weight off the wheels by means of axle stands if not moving the caravan for a long period of time. I can't find where I read it so the figure may be wrong. I would guess that taking most of the weight off the wheels would reduce the chance of distorting the tyres and at the same time maintaining the suspension in good condition. I suppose you could always use winter wheels or an old set of wheels and tyres and keep the good set locked away in a suitable place at home.
