Just found this on another forum, may help:
gmc15
View Member Profile
Add as Friend
Send Message
Find Member's Topics
Find Member's Posts
post Aug 31 2007, 04:07 PM
Post #1
Three Star
Group: Approved Member
The water has a sort of TCP taste when we used the new van for the first time. We thought it must be the site water. After trying a couple of other sites we have come to the conclusion that it must be a problem with the van water pipes. When water was used directly from the site tap it tasted OK, but when used from the aquaroll it had a horrible taste and smell. If the pipes were flushed for a long time some of the taste dissapeared but it was still not pleasant to drink.
I am going to contact the dealer to see if anyone else has the same problem with their new Bailey.
Has anyone come across this problem with their Bailey?
Graeme.
BMW towing an Indiana.
Go to the top of the pageReport Post
+Quote Post
couiza
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Aug 31 2007, 04:39 PM
Post #2
Three Star
It is common with many makes and seems to emanate from the plastic water pipes they use.
For years now we have never used the water from the caravan taps/aquaroll, especially after seeing someone who thought it was "funny" to move a pump from the aquaroll to the waste water container!
We now always fill a Brita filter from the site tap for drinking and cooking purposes.
+Quote Post
lancer
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Aug 31 2007, 06:09 PM
Post #3
One Star
One possibility is that the water system may have been sterilized at the factory before they released the unit, as an ex water board employee all water pipes are sterilized prior to commissioning for health and safety, possibly the caravan manufacturers follow the same procedures.
I purchased our unit when it was only 9 months old and hardly used but I still ran some diluted Milton through all the water pipes prior to use, it will give off a sour taste for the first few weeks but then settles down.
Remember to remove your filter if you have one fitted prior to sterilizing and replace after flushing I keep an empty filter case just for that purpose.
The original filter I noticed on our van had green algae in it and as I say it was only nine months old and hardly used so change the filters often and each season do a sterilizing flush better safe than sorry.
Bailey Pageant Champagne series 5, Towcar Kia Sportage
+Quote Post
dunclie
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Aug 31 2007, 07:06 PM
Post #4
One Star
We had the same trouble with our van, so i filled the aquaroll and sterilised that the night before we went away and kept it full until we got to the site. When we got there i ran the fluid through the system into the onboard tank and left it a couple of hours. Then i flushed the aquaroll out and filled with fresh water and ran it through the system and onboard tank, success, nice fresh water.
As Lancer says remember to remove the filter.
+Quote Post
gmc15
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Aug 31 2007, 07:35 PM
Post #5
Three Star
Thanks everyone. I used the same aquaroll that I have used on my vans for many years so I don't think the problem is there. I removed the water filter prior to flushing the whole system with weak Milton and then put about 5 fresh aquaroll's through the pipes. The water still tasted funny. When I got to the site I flushed the water system again with site water but it still had a bad taste. I tend to fill a small container straight from the site tap to use for kettle water and general drinking but the water that has been through the van pipes actually leaves a horrible TCP like smell on your hands when you wash them.
I have been on to the dealer and he siai that I was not the only person to have this problem with their new van and he has ordered a new set of pipes to replace all those on my van. I think they must have been a bad batch used by Bailey when the van was assembled.
Graeme.
+Quote Post
merseyscouse
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 1 2007, 11:00 AM
Post #6
Two Star
QUOTE(gmc15 @ Aug 31 2007, 07:35 PM) *
Graeme.
is it possible the actual filter has been contaminated prior to leaving factory....that seems to me to be the only part of the system no cleaned
05 Ford Modeo tdci 130 ghia x & 06 Bailey Pageant Burgundy series 5
+Quote Post
Hobbybod
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 1 2007, 03:42 PM
Post #7
Four Star
Thanks everyone.
. . . . . . The water still tasted funny. When I got to the site I flushed the water system again with site water but it still had a bad taste. I tend to fill a small container straight from the site tap to use for kettle water and general drinking but the water that has been through the van pipes actually leaves a horrible TCP like smell on your hands when you wash them.
Graeme.
Graeme et al. this used to be a common problem on new 'vans some years ago. I thought that it had been solved, but obviously not completely!!
It is caused by plasticiser in the plastic pipes (to make the pipes more flexible) leaching out into the water as it passes through the pipes. Sterilising etc. will have no effect.
Your dealer is doing the correct thing in replacing all the water piping, but he needs to do a check to make sure that the replacement tubing doesn't suffer from the same problem; before he replaces the water pipes!!
Cheers, Hobbybod.
My WebshotsIPB ImageClickable photo
Imported Hobby Excellent 450UB
+Quote Post
NewRangerFamily
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 1 2007, 04:02 PM
Post #8
Four Star
We never ever drink from the aquaroll, simply dont trust the aquaroll and plastic pipes as being hygenic enough. We always take a 2 litre container and keep it in the fridge and either fill it from the tap on site or, if abroad, used bottled water.
Use the van taps for everything else, teeth cleaning, washing etc.
Regards
NRF
This post has been edited by NewRangerFamily: Sep 1 2007, 04:02 PM
Seat Alhambra 1.9 SE TDi 115 and 2006 Elddis Crusader Aurora Avatar pic taken with Sharp GX25 mobile phone!
+Quote Post
barry c
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 1 2007, 05:03 PM
Post #9
Three Star
Water direct from aqua roll for washing ( personal and dishes etc )
Bottled water for cooking etc ( even just topped up from the site taps )
As for drinking water !!!!!!!!!!!!! not a chance, leave that for the wildlife ........... after 12 noon..... wine or whisky and the only thing to put in your single malt...............
Fed up with lying cheating greedy politicians of all parties just glad to be retired and trying to avoid the rat race and all the hassles that go with it
+Quote Post
JonathanM
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 2 2007, 01:38 AM
Post #10
Four Star
QUOTE(NewRangerFamily @ Sep 1 2007, 04:02 PM) *
Regards
NRF
TBH if you are worried about the qulity of water and won't drink it direct from the tap, you probably shouldn't use it to clean teeth with.
Bailey Ranger 470/4 2005 + Nissan Terrano 2.7TDI Sport 2001
+Quote Post
GeorgeB
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 24 2007, 02:22 PM
Post #11
Two Star
QUOTE(gmc15 @ Aug 31 2007, 04:07 PM) *
Graeme.
gmc15
Go back to your dealer and report this as a warranty issue. This is a known problem, the chemicals are laching out of the water pipes, no amount of flushing through will remove this taste.
Bailey's re aware of this problem and will replace all the water pipes in your van.
Just waiting for the pipes to be delivered to my dealer for them to replace them under warranty.
GeorgeB Bailey Indiana series 5 towed by Audi A4 Avant 2ltre TDi
GeorgeB
Bailey Senator Indiana series 5, towed by Audi A4 Avant 2ltre Tdi Auto
+Quote Post
Roving Rangies
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 24 2007, 02:51 PM
Post #12
Four Star
QUOTE(barry c @ Sep 1 2007, 05:03 PM) *
Snap, we use a thermal water dispenser, have used it for years now, I never drink any water from the vans taps!
Carlight towed by a choice of 2 LPG powered Range Rovers and love every minute!
+Quote Post
gmc15
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 24 2007, 02:57 PM
Post #13
Three Star
QUOTE(GeorgeB @ Sep 24 2007, 02:22 PM) *
gmc15
Thanks George. I have been back to the dealer and, as you said, it is a known problem. The dealer has ordered a full set of pipes to replace the ones on my van. There was some delay because some of the replacement pipes Bailey started to use were collapsing so they had to go to a different supplier.
Graeme.
+Quote Post
k9shaz
View Member Profile
Add as Friend
Send Message
Find Member's Posts
post Sep 24 2007, 04:55 PM
Post #14
Three Star
How many of those Milton tablets do you use for steralising an Aquaroll?
Sharon
"Inside me lives a skinny woman screaming to get out.
But I can usually keep her quiet with a Mars Bar!"
