Posting the following in the hope that it may be of interest to some Bailey owners.
Following a letter in the most recent Caravan Club magazine there appears to have been a spate of posts on other forums re whether you can safely use the bolts supplied with standard fit alloy caravan wheels with the spare steel wheel and at what torque setting. The writer of the magazine letter had apparently overheard a conversation in a caravan workshop between caravan owner and workshop re the need to use a different set of bolts.
My Bailey handbook for all Unicorn models ( bought last year and sure it is the same as my previous Senator) reads torque setting of 110nm for alloy wheels and 88nm for steel wheels. On the next page there is a high lighted section which reads that if using the steel spare then the torque settings should be "the same", now that to me reads as being the same as the alloy torque setting. Just to confuse me further I noticed, when I was looking for something else, that the on line handbook has now changed to read torque setting of 160nm with alloy wheels and 120nm with steel wheel. The advice on next page for using the spare was still "the same"
I emailed Bailey for clarification on the following points
1) although my caravan, a Barcelona, was not affected by the recent wheel detachment problems and therefore was not subject to a recall and fitting of new wheel bolts was the recommended torque setting 160nm as in new handbook or the previous recommended 110nm.
2) what was the recommended torque settings if using the steel spare in the event of a puncture, was it 88nm, 110nm ,120nm or 160nm.
I received a very speedy reply stating that in my case I should torque wheel bolts to 110nm for both alloy wheels and the steel spare.
however if I were to use the new bolts being supplied with the dry lubricant then they should be torqued to 160nm for the alloys and 120nm for the steel spare.
I also asked if they recommended that I changed the bolts to the new style even though my caravan had not been mentioned as having a problem. If it increases safety then I would rather do it. The answer to that was a bit more vague, no specific recomendation or not just that they will be available to purchase from their web site soon.
Hope this is of interest to any other Bailey owners.
Robert
Robert
