It’s but like insurance reviews the majority are written by customers based on their purchasing experience, not how well acclaim is dealt with. I had inordinate trouble trying to persuade a battery supplier in North Wales to replace a defective battery, as they were insistent I return it, and being hazardous waste ( used battery) normal couriers don’t transport them, and licensed carriers tend only to service a regional area. In the end I had to use SoGA backed up by SC court before my problem was resolved. Never again will I buy online and in the period local outlets have become more competitive. Saving a few quid is less important than keeping my stress levels down. 🔋I've always found Tanya Batteries to be a good on line supplier - either direct or through Amazon. There appears to be no price difference.
I had a Yuasa fitted at Halfords earlier this year, competitive price and 5 year guarantee.For the record the Halfords leisure batteries are rebadged Yuasa which, along with Bosch and Varta, are probably one of the best batteries made, and they are very competitively priced as well.
It's only Yuasa's cheaper ranges that are rebadged as Halfords.For the record the Halfords leisure batteries are rebadged Yuasa which, along with Bosch and Varta, are probably one of the best batteries made, and they are very competitively priced as well.
Bosch Varta Optima Lucas and a lot of other well known brands were owned and manufactured Johnson Controls a U.S. company. In the summer Johnson sold their automotive battery business.It's only Yuasa's cheaper ranges that are rebadged as Halfords.
Bosch and Varta are owned by the same company, the batteries are identical except in badging - Varta batteries are rebadged by a number of car makers, including VW Group.
There no real answer to that - although car workshops will always say less than your battery's age to persuade you to buy another.How long do batteries last for my car is 4 years + could not start it this morning so rung my VW dealer someone came to my home and they got it going . so i am hoping it going to okay we go away this weekend .
I think it because it not been use much but it now on a charger overnight and we are going up near Morpeth that about 165 miles from home .There no real answer to that - although car workshops will always say less than your battery's age to persuade you to buy another.
Battery life is very dependent on usage - my VW Touareg battery is 7 years old and going strong - but the car wasn't used for a year when I was medically banned and not used for another year during Covid - for both periods, the battery was put on a smart charger once/month.
Short trips where the battery doesn't get fully charged will shorten its life.
Most cars with stop-start have a battery specific to that purpose, usually AGM or EFB, compared to cars without stop-start. They also usually have a battery management system which switches off the stop-start if the battery charge is low - in reality this means that stop-start will activate less frequently as the battery ages.Not sure car batteries are relevant, they are different and have a different usage. A lot depends on how you treat them and use them but I would expect at least five years as a minimum and usually a bit more.
My daughter had trouble with hers due to the engine cutting out when she stopped and started in the traffic jams she encountered daily going to work. She disabled that and the battery worked, although the extra petrol used may not have been the long term cheapest option.
Hi Clive not if you are going on holiday and we will kill to birds with one stoneOur Nissan battery was 9 years old when replaced. But I did that out of caution. The Subaru was 8 years old when I changed its battery. Again out of caution. 4 years for an OEM battery sounds a bit low. But driving to Northumberland and back seems a bit extreme to charge it up. 😂
The dealer drop it off this morning it had a full charge and just said see how you go but any more problems you only have to ringI posted this in another thread and it has lots of information including a section on how long should batteries last.
As a point of interest my old Nissan Battery was 9 years old when I replaced it. It would still start the car but if you tried it a second time a short while later it wouldn't.
Thank youNo need to apologise for asking TD.
Leisure batteries are manufactured in different sizes and capacities.
Look inside the caravan battery box and measure the dimensions so that any battery that you buy will fit the available space, length, width and height.
Note which ends of the battery the +ive and - ive terminal cables enter the battery compartment.
12 v Leisure batteries are rated in amp/ hours.
The higher the number, the greater the battery capacity.
If your caravan touring doesn't involve off grid camping, on caravan rallies for example, and you don't have a motor mover, a lower amp/ hour leisure battery will be fine.
If you attend caravan rallies or off grid music festivals regularly, a higher capacity will be needed, such as 110 amp/hour.
Shop around for the best prices, places such as Towsure, Go Outdoors or Halfords are good starting points
