Bailey Senator Indiana Lights
May 10, 2007
13
Hi
We have just bought a 2006 Bailey Senator Indiana.
I can't work out how you get the lenses off the road lights to change a bulb.
Does anyone know how to do this please?
The handbook doesn't tell you...........
Dec 23, 2006
788
Trev,
To avoid causing any damage i would give your dealers workshop a ring. They should be able to tell you the correct way to remove them without causing damege .
Hamer
199
19,235
jondogoescaravanning.com
Your Bailey may be different to mine - but on mine I remove four screws and the light unit comes away from the van, held of course by the wiring. Each bulb is then removed from the bar.
Oct 29, 2007
62
Trevor,
Series 5 Indiana, to change a bulb on the rear lamps insert a small flat bladed screwdriver between the lamp lens & the body at the bottom of the lens & carefully prise off the lens by pushing the screwdrivers handle down, I usualy put a peice of cardboard between the screwdriver & the vans body to protect it
Feb 16, 2009
1,144
Depends if they have the rubber grommets, they tend to give a problem when removed, you then need to replace with new to give a good fixing, most good dealers supply.
NigelH
