- Mar 14, 2005
- 663
- 0
- 0
Hi all, we took delivery of a 2007 Bailey Senator Arizona just before Christmas, used it a couple of times and so far so good with no problems. That is until this weekend just gone, used the shower for the first time, filled the aqua roll to ensure we had plenty of water and in to the shower I stepped. To start with the water pressure was not too bad, not as good as I imagined it would have been, but then the pressure slowly started to drop almost as if we were running out of water. I then turned the shower off left it for a minute or two then tried again, same result okay at first then slows up!!! Could it be that I am not using the onboard tank? But instead pulling water direct out of the aqua roll and the filter could be impeding the flow? Both the kitchen sink and the bathroom sink seem fine but obviously these require a lot less pressure than what the shower does. Your thoughts and suggestions would be much appreciated before I start calling the supplying dealer. And I also found that the hot water did not seem to last for to long, or is it me that has lost the knack of using a caravan shower after returning from a fixed bed model where the shower room was so small it was neither use nor ornament, so we never used it, apart from once and once only when I ended up trusted up in the shower curtain, lol
Allan & Gill.
Allan & Gill.
