If I couple a twin axle caravan up to a estate , will the tag axle lift off the ground or is they something to keep on the ground. Or does the wheel not lift off the ground?
Dustydog said:Hi Mikaroony
You are certainly going through the list of manufacturers!
Sometimes it's best to take a step back and establish the maximum safe MTPLM your car can handle.
Years ago we had to compromise until we could afford a 4x4 and get a TA.
However as Lutz will say there are SA's out there just as big as a TA.
Once you have established your maximum weight then check out the layout that will best suit you. Thereafter have a good look at all the manufacturers wares but in particular ensure you do buy from a reputable decent dealer not too far away from home / storage.
