- Feb 4, 2014
- 346
- 0
- 0
I'm just wondering how everyone else goes about charging up their battery? I've got a CTek Intelligent charger (Ah, there are some brains in this household after all!) I understand it's quite acceptable to charge up the battery insitu, and in fact the instruction manual suggests it's ok to leave the battery on charge all the time when the 'van is not in use. I can't see the point in doing that. Surely it's a bit like leaving your T.V./laptop or whatever, on standby all the time? Also, there is the potential for an electrical 'accident' to occur, when the weather is wet. I keep the cables under the caravan to try to keep everything dry, but prior to my last outing I had wrapped the socket of the extension cable in a plastic bag to make sure it kept dry - but it didn't work! Fortunately I found the water in there AFTER I'd switched off the cable at the mains. The alternative of course is to take the battery out of its little cubby hole and take it indoors to charge, but that seems like a bit of a *** to me. Also, they're rather heavy. Is it possible to get a weather-protected socket fitted to the front wall of the house, so that I don't have to dangle the extension lead out of the window? Sorry if these queries all seem a bit obvious; I'm afraid I'm being a bit of a girlie here. Thanks folks.
