Can I put a two bike bike rack on the back of my Elddis? I realise it would eat into the load capacity but is the rear panel strong enough?
IBH said:Be very careful as it will change the dynamics when towing due to the extra weight being moved to the back. Most caravan experts (and I am not one) say that it should not be done.
colin-yorkshire said:the weight of a bike or two will not make any difference to the balance of the van, however the main concern would be the weight on the rear panel and of course drilling holes in the outer skin.
Sproket gives good advice follow it!!
the question was about the balance of the van and its effect on stability and aerodynamics and would the rear panel carry the weight, not the nose weight which incidentally 99% of vans is too heavy anyway and have to be adjusted before towing,MichaelE said:colin-yorkshire said:the weight of a bike or two will not make any difference to the balance of the van, however the main concern would be the weight on the rear panel and of course drilling holes in the outer skin.
I would disagree with not making any difference as even a few kgs on the back with the pivot being the wheels increases the effect on the nose weight..
If they are fitted on the back you will have to compensate to make the nose heavier.
Your reply was saying that a few kgs wouldn't make any difference when in fact it wouldcolin-yorkshire said:the question was about the balance of the van and its effect on stability and aerodynamics and would the rear panel carry the weight, not the nose weight which incidentally 99% of vans is too heavy anyway and have to be adjusted before towing,MichaelE said:colin-yorkshire said:the weight of a bike or two will not make any difference to the balance of the van, however the main concern would be the weight on the rear panel and of course drilling holes in the outer skin.
