Anyone know how to connect bluetooth to a fitness trainer, problem is I already have a code which is not the fitness trainer code, it just will not pair up,
Thanks gor the info managed to sort it outI think what is happening is that the fitbit and iphone talk to each other when you are connected to wifi. To use bluetooth you should switch blue tooth on on the fitbit and then put iphone into search bluetooth. The latter should happen automatically when you open the bluetooth settings. If it doesn't switch bluetooth off and on. It should then find the fitbit, click connect. If a code is needed the fitbit should generate it and you just type it into the iphone. You might find something in the fitbit app settings. Haven't used a fitbit but wife has an apple watch and iphone. The bluetooth will allow the two devices to talk to each other when you are away from wifi. So if you reach a target the fitbit should ping or whatever. A word of warning the bluetooth might run the battery down faster especially if you use the iphone for music etc simultaneously.
