Jun 20, 2006
A freind of mine tows a elddis with a bpw hitch as do i but he is complaining of a sort of cracking noise from it when towing I do not have this problem and the only thing I can think of is dirt in the pads.
Has any one had the same problem or know what it maybe and remadies to fix this thanks for any advice.
Jul 15, 2005
2,175
Creakign from the stabiliser is almost 100% due to contaminated friction pads - the only other probable cause is cracked or broken pad (usually from dropping the tow-hitch onto the tow-ball)
Let's assume it a dirty tow-ball, so make sure all paint or plating has been removed from the tow-ball, that's it's clean and free from rust or other contaminants.
Then clean the friction pads inside the coupling head - you can do it in place - just use clean cotton rags and keep wiping until any deposit has dissappeared (white rag is best for this)
That should fix it - but if there is fgrease or oil contamination then either white spirit or brake cleaner will help it to be wiped off.
If it still creaks after all this, then a final things to check:
1. Remove the pads and see if they are cracked - replace and don't drop the coupling onto the tow-ball again
2. If the pads are in one piece, but obviously look engrained with contaminants - then resurface the pads with emery paper
3. If this fails then replace the pads
4. If this fails then replace the tow-ball - some tow-balls are mirror smooth and some have a very noticable set of machining groves running around the tow-ball - like our Bosal detachable - and those with goves seem to be the quietest - but getting a different tow-ball can be a lottery.
Robert
Jun 20, 2006
Robert
Thanks for the advice Robert will get him to give it a go.
