My lad has a two year old dealer special based on the mid washroom Swift four birth.
The bracket holding the brake rod that supports the brake rod has dropped off and it appears there is nothing to fix it back too, even a temp fix. As it is the the rod is bowing as he brakes then straightening, putting brakes on suddenly.
What is the new floor sandwich made of, seems it's a plastic sheet glued directly to the foam. No reinforced area to screw into. After all it should be the easiest of fixes.
Any ideas even for a temp fix, enough for a smoothest ride to the dealers.
