Hi .I have a small 800 kg caravan with break away cable set up as legal in NZ.i have also fitted a caravan chain to car.Is it acceptable or safer to run with both set up together or not advisable or one but not the other.cheers.
Thanks.My argument for having both is provided the chain is shorter than the cable for this 800 kg caravan that one could not affect the other .Safety of other road users would be enhanced . Damage to your own vehicle would increase though.But is that manageable? Or does it make your own situation dangerous? Or illegal?
No idea of the legality as you should check with the NZ government regulations.
I really cannot see any benefit for your idea. Within Europe (inc UK) there are tens, if not hundreds of thousands, of caravans out travelling at speed of up to 60mph. All are or should be fitted with breakaway cables and do not have chains. Have we got it wrong. A common incident is failure to lock the caravan to the lowball when leaving site. The breakaway cable works immediately and brings the van to a halt without damage to car or caravan. apart possibly minor to the caravan under A frame area, depending on speed and surface. In your proposal it would be the chain that takes the strain first, thus preventing the breakaway cable from doing its job. So you could, depending on the strength of your chain, drag the van with its nose dragging along the road, before you intervene.
At higher speeds on road I really don't know what the dynamics would be, it depends where the unhitching occurs and at what speed. You could even be jeopardising other road users
I think you should drop your idea and stick to the breakaway cabe only.
In that video the outfit were travelling at A road speed. It's naive to expect anything be it cable or chain to control and brake a free wheeling caravan under all circumstances. A loose caravan strongly attached by a chain can still veer into oncoming traffic and pull the tow car all over the place too.However recently on this forum there was a video of a caravan that became detached and travel quite a distance on the wrong side of the road before it came to a halt.
Even if the brakes operated perfectly when the breakaway cable was activated, the caravan will still travel some distance before coming to a halt and in that distance it could veer into the oncoming traffic.
This should not happen with a chain however as you say the OP needs to follow the local regulations and not the EU regulations.
If attached by a chain it is highly unlikely to veer across the road as the car towing should keep it in a straight line. Also very unlikely it will pull the towing car all over the place as it is still attached to the car. Maybe a different story if the caravan is badly loaded, but we had a very active traffic force in SA at the time so not worth taking the chance.In that video the outfit were travelling at A road speed. It's naive to expect anything be it cable or chain to control and brake a free wheeling caravan under all circumstances. A loose caravan strongly attached by a chain can still veer into oncoming traffic and pull the tow car all over the place too.
ISTR that caravan was on a dual carriageway and came to a halt in a fairly straight line against the central armco?
Spot on. Rather the back of my car damaged than someone being injured. I have since found out that the chain is not longer required in SA and many trailers are now fitted with the electric brake which is supposed to be more efficient all round, but no idea how it would help in the event of a trailer becoming detached.At speed a breakaway chain would stop the caravan but it is going to take longer and it could veer off anywhere so the outcome is indeterminable. With a chain it should stay behind the car but whilst that might prevent it getting in the way of others or running into the side or central barrier or even oncoming traffic it will almost inevitably hit the tow car or without the control of the tow bar turn over. There is no right answer, it all depends on when you need it and the circumstances surrounding you at the time and possibly luck.
Possibly if it lost electrical power the brakes would activate. But that would need careful design as you don’t want the brakes to activate if for some reason electrics failed when towing. But it’s doable.Spot on. Rather the back of my car damaged than someone being injured. I have since found out that the chain is not longer required in SA and many trailers are now fitted with the electric brake which is supposed to be more efficient all round, but no idea how it would help in the event of a trailer becoming detached.
In Australia they use electric brakes and chains - seems strange to remove the need for chains in SA if not replaced by a breakaway cable.Spot on. Rather the back of my car damaged than someone being injured. I have since found out that the chain is not longer required in SA and many trailers are now fitted with the electric brake which is supposed to be more efficient all round, but no idea how it would help in the event of a trailer becoming detached.
I think that with modern cars if you lost power, the braking on the caravan would be the least of your worries especially if on the motorway i.e. very heavy steering etc.Possibly if it lost electrical power the brakes would activate. But that would need careful design as you don’t want the brakes to activate if for some reason electrics failed when towing. But it’s doable.
I actually said “ electrical power”I think that with modern cars if you lost power, the braking on the caravan would be the least of your worries especially if on the motorway i.e. very heavy steering etc.
They may now use a breakaway cable plus chains as Swift imported caravans into SA. I did find this;In Australia they use electric brakes and chains - seems strange to remove the need for chains in SA if not replaced by a breakaway cable.
Perhaps it relies on the car slowing and the caravan hitch contacting the car and activating the over run. That would require the driver to be aware something is amiss, or maybe a slow down due to road conditions.Quite how is a breakaway chain going to put on the brakes, as is being claimed here, if as implied it is a trailer with a cable breakaway system?
