Broken caravan Mirror
Aug 11, 2013
27
Hi all just got back from a 2 week holiday in Cornwall today only too find when opening the caravan up that the mirror cupboard door has can off and mashed can any tell me were I could get a new mirror/door
Adrian
1,324
Hi Adrian. You don’t say what van it is. If it is a Bailey then Prima Leisure sell the spares. For an Elddis you have to order through a dealer. A Caravan breaker like SFM may also be able to help.
1,497
419
19,435
From the Swift stable then so you may have to get one via a dealer or google ‘caravan breakers’ and see if you can track a used replacement down.
1,792
I doubt Swift will be able to provide a new door but you can check with a dealer and otherwise I am afraid a breaker will be the only other route. I would assume that the cupboard will be fitted to various Elite models for that year so you would need to measure it to confirm. Other Sterling ranges will probably be a different colour.
If you want to replace the mirror if you give any glass firm the size they should be able to replace it.
2,085
Glass mirrors are heavy - some caravans used silvered acrylic mirrors which are much lighter but difficult to cut/drill outside of factory conditions.
1,324
Try O Leary
I know it is not this door, just posted as an example.
Otherwise it will be a Swift dealer but take pain killers as it will mean a radical walletectomy.
good luck
mel
  • Haha
