Butane/Propane
Sep 13, 2006
1,411
Does anyone know how much heat (Therms, calorific value or any relative heat measure?) you would get out of a 15kg Butane bottle compared to a 13kg Propane bottle. The bottles are the same size and I am assuming you would get less from the propane bottle.
I have just changed to propane for the winter and am wondering the merits of changing back in the spring.
Sep 13, 2006
1,411
Apologies for answering my own question but others might be interested
I found this almost straight away on the calor website
"Commercial Propane = 13.83 kWh/kg
Commercial Butane = 13.62 kWh/kg"
Which I have just worked out taking different bottle weights and prices from Calor means that Propane is appx 3% more expensive to run on then Butane.
This means I will not bother changing back in the spring, I thought the difference might be more.
4,104
Hello Garry,
You may find that you can obtain Propane from other suppliers which might redress the the small cost disadvantage.
