Leisure vs Starter batteries for movers,
I think there is a lot of misunderstanding regarding the type and capacity of battery required to run a caravan mover.
There are two main factors you need to match. The first is the peak current draw for the mover, The battery must be capable of supplying this current, and then there is the total power used by the mover when in use, which is often far less than you might imagine.
All dc motors have a high stall current when the motor is trying to get going, but as soon as the motor starts to spin the current demand falls quite dramatically to the normal operating current. Unless the motor is jammed, the transition from Stall to operating will take less than a second.
So when the motor is trying to start you get the "Stall" current, and when the motor is moving it will use a lower "operating" current. It is not uncommon to find a 10:1 or bigger ratio for the stall current compared to the operating current of the mover.
Most motor manufacture do not quote "stall" currents but will provide operating currents. So to work out the stall current multiply the quoted current by ten to obtain a rough estimate for the stall current
The battery peak current capacity of the battery needs to match or exceed the stall current. In car battery parlance is the Cold Cranking Amperage (CCA) or Peak Current.
The total current (Ah) used by the mover is less than you may think, because it is generally used for short periods of time. Taking Colin's figure of 15Min and even his quoted current usage of 60A (more on this in a moment) As he is only using it for 15min or a quarter of an hour this means his Ah usage is 60A for 1/4hour = 15Ah Put into context that is one internal 12V fluorescent lamp running for 10 hours
It is more than likely that Colin is over estimating the current he is using, as the 60A is the motor working at full capacity for the whole period which will be the max weight of caravan being driver up a 1:4 or 25% gradient continuously. It if far more likely that much of the time the motors will be drawing much less than the 60 probably more like 15A so the power used now falls to 15A for 1/4hour = 3.75Ah (lets be generous) 4Ah
So you don't need a big battery to run a mover, only one that can meet the motors Stall current. If a battery can supply a peak current of 600A there should be no problems.
