Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
I have a a 1998 Elddis Hurricane GTX fitted with a Rose 6070 oven. It will light on its first setting but will not pick up to a full heat flame. Is it the Flame failure device, can I replace it or do I need a new or secondhand oven?
Is your regulator OK? If the gas rings have a flame that comes off the ring as well it might be the regulator, allowing the gas to come through at too high a pressure.
If I understand you correctly, the oven will light and operate on a low setting but will not not operate correctly on a high setting.
As Chris says, the flame could blow out from too much gas, which points to a regulator fault or just the wrong regulator.
Or you may not get full gas flow. A longer list of possible faults this time, a faulty regulator that is restricting flow, a partly blocked main jet, or a faulty flame-out sensor.
The possible cause is a blocked jet due to grease from cooking but I agree with John, it needs sorting by someone who understands the system as there are several other possibles.
