caravan spares or lack of them
Apr 21, 2007
20
Got A 2005 lunar galaxy (LEXON) The water pipe under the sink split, do you believe that lunar or 3 other caravan shops could not get me a replacement, i know they use odd sizes in caravans but wouldnt you think they would keep some sort of spares. Had to modify the pipework to get the repair sorted, so be carefull on what you buy and make sure they keep spares like this in stock. The pipe in question was a 10mm monobloc to a 1/2 inch female end.
Aug 2, 2006
437
Hmm - does seem a bit of a basic component to struggle with - especially when all caravans use the same diameter pipework. Did you swap to a domestic-sized fitting?
Apr 21, 2007
20
The pipework is 12mm, so had to put a compression fitting 12mm to 1/2" then a 15mm pipe to a push fitting 10mm monobloc pipe, was a bit confusing to say the least, but it worked ( fingers crossed )
