Hello John,
I will warn readers now this is a long post, it has taken along time to compose it, and it will be by its nature quite detailed. So if you don't want to be bored stiff don't read it and don't complain about it. By all means challenge salient facts or assumptions I have made.
JohnMW said:
Hello JohnL
Thanks for the post - I know of the Bath University project and have been a critic of what they have come up with after 25 years of investment - nothing. The model they produced only demonstrates what happens when there is a negative load on the nose and what we all have witnessed that make it positive and it helps a lot. If they had a hand in the Alko project then I think they should go back to the maths and the models and I have said so on their YouTube site. I do believe it was a migrant students who worked on that Not Dr Josh. However, I would be confident in sitting down with who ever and explain one or two things when the time is right. Just to be clear if my system were tested to destruction I dare admit there will be limits - even the very best things made have limits - go to Calculus and you can see where they are. Caravans can blow over if the wind is strong enough - they can skid on ice if you go too fast in those situations - i guess you and others will see where I'm coming from. I do not see any differential offerings from BPW or ALKO they only work of simultaneous braking of both trailer wheels - only Dexter have used this concept in America on ELECTRIC BRAKING SYSTEMS. I applaud Dexter for recognising the differential concept (Used on aircraft and agricultural braking systems) they have limited capability compared to mine - they shut off when the going gets rough, they do not sense jack knife
situations, they cannot present an equal and opposite force at the centre of equilibrium, they rely on electronics heavily and they cost a lot of money, they don't have one working on overrun brakes yet.
Many thanks
I think you underestimate the involvement of the staff at the University of Bath, and whilst the often demonstrated Bailey model is a simplified model of the issues involved, it has demonstrated the importance of loading strategies in a way easily digested by most caravanners. The origin of the student involved with the study is totally irrelevant.
The University of Bath have been involved with extended projects usually in conjunction with a commercial sponsors, and they have a good reputation in the field vehicle dynamics and engineering in its wider forms. This is one way they bolster their funding by offering research facilities to the commercial sector. Such programmes are always overseen by senior university staff to ensure that not only do the programmes meet the clients criteria, but they also provide opportunities for students to have real world experience.
It is common for a student to use these programmes, or at least part of them, for the basis of a final project and dissertations. Their final papers may not contain the greater project outcomes which may be protected for reasons of commercial confidence. If a student paper seems to have a very narrow field of application, there may be other control criteria that prevents the student for expanding the subject.
Don't forget that good research projects do not always end up supporting the initial hypothesis. During the course of a project the results and analysis may start to show why the initial hypothesis is untenable. They may end up supporting the the null hypothesis, which may be as valuable, to prevent wasted investment on chasing a less effective ideas.
U of Bath have served Bailey Caravans, Williams F1, and other significant manufacturers in the automotive and caravanning sectors. I seriously don't think these companies would continue to use UofB if their project management were seen to be less than perfectly satisfactory.
Forums are not the best way to get into meaningful discussions with organisations, you need to make a more formal direct approach.
I can full understand that you will have used mathematics to help you with your concept. Calculus is one of several mathematical tools and may be necessary to produce the model to describes your system and provide predictive information on behaviours. But I would be very surprised if the chassis manufactures do not also use mathematical modelling, probably linked to CAD/CAM systems, so your approach to problem solving is not fundamentally different.
However most laymen will be perfectly able to conceive that road and weather conditions can and do affect towing behaviours, all they are primarily interested in is having a safe method of managing these characteristics. A knowledge of higher mathematics is not required, only the funds to purchase the equipment.
I can comprehend that differential braking might offer some advantages over shared braking and how that may be a benefit to aircraft especially on landing, but the agricultural comparison is not really fair as its purpose is somewhat different and usually performed at much slower speeds.
I have to assume you are referring to the caravan braking systems when you claim that some of them shut off when the "going gets rough". I have seen no other reference to your assertion, and the companies information about them certainly makes no mention of it.
It was my belief that the ATC system supplied by Al-Ko used differential braking. However I made further enquiries and I stand corrected. I cannot find enough information about the BPW system to be certain but I suspect it does as you say, work on both wheels simultaneously. But contrary to your later assertion, it is very clear that both Al-Ko and BPW do have systems that operate on Over run braking systems.
Reliance on electronics is not automatically a bad thing, It is true that electronics can fail, but so can all mechanical products. Good design of electronics can bring MTBF rates to exceeding low levels and often somewhat better than mechanical processes. Talk to your son about the electronics he uses.
You obviously genuinely believe you have a wonderful product idea, and if it's really as good as you say then I think all caravanners would want one. But it does concern me how you have presented your situation by making exaggerated unsubstantiated claims for your system, for example "nothing to go wrong" and "more reliable than electronics" also how you have sought to undermine the competition, again by making unverified claims of their systems failing when "the going gets tough" etc.
This is not advertisers license but false advertising bordering on libellous. This is not the way to impress possible investors. Stick to provable facts, and give citeable evidence.
Best of luck. PJL
