Carver Cascade 2 Gas Fault
Feb 8, 2013
29
I have an intermittent fault with my Carver Cascade 2 when running on gas. Sometimes it works absolutely fine but other times it fails on ignition and I get the red light of doom.
I have checked and cleaned the burner module recently and it worked absolutely fine. A week later I tried it again and it failed on the ignition cycle. I took the cover plate off and my wife clicked the heater on inside the van. The ignition clicked away and the burner lit fine but then failed at the end of the cycle.
Gas must be getting through ok and I'm at a loss to figure out what is wrong.
Any ideas would be much appreciated. Thanks.
