Hi there,
A friend is thinking of buying an 1992 ish, Elddis xl,4 berth, one owner from new, asking price £2000.
After a good look around, and deciding it needs a new carpet and general clean, it seems OK!
However after closer inspection a small section of the internal ceiling panel above the front lounge seems to be sagging in. We looked at this and cant find any damp, is there likely to be a serious problem here or as we suspect has the glue which holds roof and ceiling panel just parted company. The sagging is not bad and nothing that you would notice without looking for it, and its only sagging in by about a couple of inches at most in a small area.
The other fault we found is that for some reason the shower / changing area has had its ceiling area wallpapered of which is peeling off, after trying to get our hands up behind the wallpaper again there does not seem to be any problems!!
Any advice on this is greatly appreciated!
Also does the price sound good or bad??
Cheers
Andrew.
Cheers
Andrew.
