Cistern drain valve - Bailey Ranger 470/4 2008
Hi, I am struggling to find the right part/replacement for the little drain valve for the cistern on my bailey Ranger (470/4 2008).
The valve is located in the waste compartment to the top left.
I am unsure if the previous owner has made a makeshift value as I can see plumbers tape being used.
Can anyone advise on the correct valve I should be using?
On my Coachman , it is just a little rubber pipe with a bung in it, only ever drain it in the winter, sorry no photo.
I think this is what you are looking for:
By the looks it should simply push into the 'stub' of the drain hole instead of the 'lolly-stick' plug fitted to yours. The flexi pipe allows you to drain down the flush tank into a bucket et al. Grand cost of £11.70 post free!
