Cleaning the waste master
2,069
i would use some Superclean liquid is a specially product suitable for cleaning your Wastemaster.
One 250ml bottle makes 30 litres enough to throughly clean a Wastemaster twice ,
1,865
6,935
Bleach diluted. Works well and is cheap. After this a flush then a bit of pink flush fluid to make it smell beautiful.
1,332
507
19,435
I’ve found that any odour coming from the wastemaster outside and underneath the caravan can only be detected if I lay on the floor under the caravan and rest my head on the wastemaster, when it’s being transported empty between sites the 2 screw caps keep any odours contained within.
BP
1,792
I rinse it thoroughly before leaving a site and that seems to be enough. With the caps screwed on tight we have never had any problem. I would tend to go with a bit of bleach if you need to do more though.
To get a smell you have probably got some solid matter that has rotted and possibly a good rinse should clear it.
