Hi
I have a Coachman Laser 655 and have a continual problem with the water system. The can has an onboard whale water storage tank, a Truma barrel pump, solenoid valve and flow switch. The control is done on a BCA control panel.
The issue is a continual chattering from the solenoid valve. Interestingly, it chatters even if the wires are disconnected from it and at the same time, the pump rapidly switches on and off (whichever pump has been selected). The solenoid valve and flows witch have been fitted with direction of flow towards the onboard tank. I'm at a loss as to what is causing the fault (and don't really understand how how the whole system works).
Any suggestions would be appreciated.
TIA
TIA
